Recently my daughter got a real good deal on a set of 185/70 X 15 tires to replace a very old set of 195/70 X 15 mounted on 72 spoke Dayton wheels.
Some time in the past I had changed the wheels to be tubeless by sealing the spokes. At the time we had trouble when mounting the tire the sealant would be ‘pulled off’ the outside rim when the tire was seated. We figured out if we really ‘soaped’ up the bead and rim they would seat without leaking.
One tire is leaking a lot while the other 3 have slow leaks. I plan on identifying which spokes are leaking on the worst tire and reseal it. Then run a strip of black duct tape around the inside of the rim to ‘protect’ the spokes. If I can get the worst tire fixed I figure the rest should be easier.
My questions are:
1. Recommendations on sealant to use. I don’t remember what was used the first time but it is a light tan color. I’m planning on using clear silicone this time.
2. Will the black duct tape work? If not, any recommendations on what to use.
3. Chuck it and go with tubes. If so what should be done with the old sealant in the rims. I don’t think it is tube friendly with flexing.
4. Are the rubber bands that originally were use still available?
(when I tried to change one word in my previewed first try I lost the whole post – what did I do wrong?)
Thanks for you help,
My questions are:
And also have a question. Many use silicone to seal the hub to prevent antiseize/grease transfer through the hub and down the spokes. Have any of you suffered any fisheye upon repainting because of it? Is this a problem, and or is there another product to use besides silicone? -- elrey
