My cylinder bore is right at stanard size for my 1500. If I hone, could it push my cylinders past standard tolerances thus requiring an engine bore? How much does a hone typically take off?
Check bore size down in the bore, bout half way down or more. This is where you will find an egg shaped bore. check perpendicular(did I spell that right?) to crank.
Nope. they will and in some cases they will wear at the bottom of the bore lateral to the crank too(caused by I believe crank flex)! the piston doesn't care about a V or not it only sees loading from the rod against the bore side away from the rotation.
