sultanoswing
I'm putting some 7" Cibies on my 71BGT. I'll (at least initially) be running standard 60/55W H4's.
I'm planning on creating a relayed sub-harness, but there seems to be debate about to fuse or not to fuse?
I WAS planning on running two fat (4mm) brown wires from the alternator (85 Amp Bosch) post and placing a 30 Amp inline fuse into each side, then running this into two 40 Amp 5 pin relays, from here to a 4 fuse blade-box (15 Amp for high beams, 10 Amps for low beams), then out to the lights themselves.
However - it seems to me there is debate about the safest way to fuse things. One main (albeit fat) fuse can blow, resulting in total loss. I'm trying to avoid this by running seperate high and low beam main feeds. I appreciate a 30 Amp blow is a low possibility and that fusing is of course designed to reduce the wiring harness from totally frying. The guy who wrote THIS PAGE is dead against fusing headlight circuits.
I guess what would be better would be to wire things so that each main feed supplied a left and right side only - that way a mainline blow would result in loss of one side only, but I can't quite figure out how to do this without introducing uneccessary complexities and wire taps!
What are your collective thoughts??
