While there should still be an improvement, don't forget that you're still going to have four (4) very big pulses for each revolution, ninety (90) degrees apart.mjobrien said:Interesting - I'm having my lower end redone due to a sloppy rebuild by the prior shop and having it balanced as well. Will be interesting to feel the difference....
Hi Randy,Randy Forbes said:While there should still be an improvement, don't forget that you're still going to have four (4) very big pulses for each revolution, ninety (90) degrees apart.
The inline 6-cylinder is inherently smoother, having a (power) pulse every sixty (60) degrees of <span style="font-weight: bold">crankshaft</span> rotation. Balancing one of these still shows a marked improvement.
Hmmph!GregW said:Hi Randy,Randy Forbes said:While there should still be an improvement, don't forget that you're still going to have four (4) very big pulses for each revolution, ninety (90) degrees apart.
Isn't that camshaft degrees? 180° crank rotation for a 4 cyl, 120° for a 6.
