jcatnite
Hello everyone, I have a question about tire wear. When I bought my 76 Midget, the front suspension was totally worn out. The tires wore on the inside edge significantly over the first 2K miles. Since I have rebuilt the front suspension completely with rubber bushings, new tie rod ends, better than new shocks (thanks PeterC) and rebuilt swivel axles ( I reused the king pin bushings but replaced everything else). Anyway, now after around 3K miles the tires have worn significantly on the outside. Any ideas? I haven't set the toe-in yet but I did put the new tie rods in the same place as the old. I have recently bought a toe in gauge but haven't used it yet. I'm also waiting on the tapered roller bearing conversion kit to come in, then I'll set the toe. Anyway, just wondering if you guys had some thoughts. It would seem as the camber is way off but I can't see it by looking. Guess I'll check it with a square when I get her off the jackstands. Feels like I'm constantly swimming upsteam...
Thanks,
JC
Thanks,
JC
