Tire size
jmc948
I'm trying to decide on a diff ratio for a BE, and tire size is obviously a variable in the calculation. Assuming a stock 1275, 3.9 differential, a stock body with no fender flaring, and no more than a quarter-inch spacer on the rear wheels, what tire size are people using?
And what do you think is the widest tire that would fit the above description without rubbing?
J
jmc948
Doh. I was assuming the standard 13" wheels. They're probably narrower than I'd like, so I guess I should modify my post to:
. . . what wheel and tire size are people using?
davester
On stock wheels I'm using 165/70-13. Same diameter as the originals but a bit too wide for the stock rim width.
GeeBee1
If you are using stock BE rims, no larger than 155 80 13.
Definately Z rated. :driving:
Pat
Gundy
Just to throw a monkey wrench in the gears here.
I'm running 185x55 on 15x5.5s.
They must wind up close to original height since the speedo
is darn near spot on according to my GPS.
Yeah, I know...weirdo tire combo on a weirdo modified BE.
Hey, it fits my style...
:driving: :jester:
Billm
Dave
Are those Calif plates or do the ones from SC just look the same?
BillM
Gundy
That is an old photo with Cali plates.
I currently run an old blue/yellow front
Cali plate that came with the car. "Heybugi"
I ordered a custom plate for SC that says the same for the rear. "Heybugi".
I just yesterday got my new tags for the FZJ80. Boykin plates.
Sprite, the new pup, approves.
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
M TR5/TR250 Compatible Modern Tire Size Triumph 5
F TR2/3/3A Spare Tire Size Triumph 11
vette Tire Size and Improving Rear Brake Drums Austin Healey 17
D Series II E-Type tire size Jaguar 9
H BJ8 tire size Austin Healey 14
T TR5/TR250 TR-250 Tire Size Triumph 6
NutmegCT Tire size substitution Restoration & Tools 4
B experience with tire size changes? Other British Cars 2
B TR2/3/3A Tire Size Triumph 14
britlover proper tire size to replace 5.90-15? Austin Healey 16
S General TR Tire Size Triumph 18
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
B T-Series MG TD metric tire size MG 5
B New VTO wheels ?? Tire Size for TR3 Racing 7
B VTO Wheels/Tire Size Triumph 13
O TR2/3/3A TR3 Wheel Swap and Tire Size Triumph 10
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
R TR2/3/3A TR3 Tire brands and size Triumph 5
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
60TR3A What Size Tire is Ideal for a 15" X 5.5" Wheel? Triumph 29
tmc Tire size for the spare Triumph 10
V Tire size consensus Triumph 4
ekamm TR2/3/3A 3a steel wheel tire size? Triumph 14
L What size tire will fit... Austin Healey 17
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
toysrrus RE: Tire Size Suggestions Wanted: Triumph 5
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
MTribe TR6 TR6 tire size photos? Triumph 30
tomshobby tire size? Spridgets 11
D Tire size for 73 midget Spridgets 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
6 Tire size conversion Triumph 0
htchevyii MGB need tire size recommendations for 77 MGB MG 6
E BE Tire Size Spridgets 20
L Street Tire size for 60 spoke wheels Austin Healey 15
Steve P. 5" aftermarket rims, what tire size needed??? Spridgets 3
N TR6 Opinions on 205-70R15 tire size for TR6 Triumph 11
I Bugeye tire size Spridgets 3
longbridgehealey Tire size Spridgets 12
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
Morris Stock tire size Spridgets 11
R Group 44 tire size ? Triumph 0
JPSmit Tire Size website Spridgets 3
Dave Richards Yet Another Tire Size Question Austin Healey 11
TexasSprite What tire and size for Minilite wheels? Spridgets 1
