Gundy
I was doing some routine stuff on the BE today.
Adjusted the toe in a little from 1/8 to 1/16.
Adjusted the valves. #4 was way off. Cam calls for
16 and 18 for lash. The #4 was 20. Annoying tick is gone.
Anyway....I checked the tire pressures. 10 lbs in the fronts and 18 in the rears. The manual called for 18 and 20 or so.
These tires aren't stock. 185x55x15s. I went with 22 lbs
in all four. I note the manual calls for 24 lbs or so for
high speed driving with stock tires.
Is there any way these things would require such low pressures?
At 10 lbs in the front I'm surprised I didn't pop a bead on a hard run up a mountain recently.
Am I screwing something up running 22 lbs?
Hi Guest!
