Stags actually use a double boot. There is an inner rubber boot that is more or less flat (with corrugations for flexibility) and then an outer leather boot. You could try adding something like that to the TR, but you'll probably need to make some holes in the tunnel for anchoring the outer boot.
Drive up here, 300 miles to the Northeast, and that heat will be appreciated. TomHi guys - even with the shifter boot in place I am getting a lot of heat coming up through the shifter opening. Anyone have some tips on how to better control that?
Thanks.
Ha.
OK I got the lower gear shift from Moss today and went to install it, and of course that opened up another question. It looks like the PVC tunnel has had its opening ovalled out. I just installed the lower seal but it wants to pop a lip out and I'm not sure it's going to seal properly.
Anyone use a sealing tape or adhesive to keep it in place?
Thanks!
Wrong answer Tom! Ha.
I am going to look around a bit at other ideas of securing it in place before ordering a new one since I want to get on with driving the darn thing, and to be honest was looking for an easier fix that than.
I'm not saying you aren't offering up a good idea, and to be absolutely clear I appreciate the response, I just want to try being creatively lazy on this one and see if I can make what I have work well. Grin.
Creatively Lazy in my mind = duct tape
Cheers
Tush
