Tips for locating/fixing foam rings under gas tank
tdskip
Hi guys - any safe tips to pass along on how to keep these from moving while installing the fuel tank?
#5 below
And do y'all install the neck/hose first (#16 above)
Thanks!
A little DumDum or contact cement works, or something sticky works.
Re: Tips for locating/fixing foam rings under gas
I've used spray adhesive and rubber cement with good results before on the TR8 foam strips. If the foam is bad, you can get rubber/foam gaskets that are used for sealing boat hatches at Walmart and similar places.
