TR6 Timing using a vacuum gauge
bonzocfi
Just bought a 74 1/2 TR6. 73,000 original miles. Pertronix ignition. Will connect the gauge to the ARV. As I rotate the distributor, what should I look for? A specific pressure, the highest pressure, steady pressure? Thanks for your help.
poolboy
If you have a stock TR6 cam for that year AND if you are at sea level, you should find the sweet spot when the manifold vacuum is in the 17 to 20 in-Hg range. The idle speed will change as the timing is changing. Make idle adjustments at the carbs as necessary for 850-900 rpms.
As usual, clockwise rotation of the distributor advances the ignition.
When setting the ignition timing it's equally important to take note of the Vacuum Gauge needle's movement...Anything more than a quiver might be indicating a particular problem.
The various "SCENARIOS" are at the bottom of this link.
https://www.secondchancegarage.com/public/186.cfm
B
bonzocfi
I forgot to mention that the retard unit had been replaced with the vacuum advance. Do I still need to disconnect the vacuum line at the distributor and plug it?
poolboy
If you have the Advance module connected to the proper location on the carb, there will not be enough vacuum to activate the advance when the engine is idling, so the answer is 'no' you don't need to disconnect it and plug the nipple on the carb.
poolboy
I am from Baton Rouge; I lived in Shreveport for a while, then moved to New Orleans, then Hammond for a long time before retiring and moving to Mississippi...It's pretty nice out here in the country.
gbtr6
Decided to check my rebuilt engine. Got 15" at 1,000 rpm idle. Advanced the timing and got 17". It has a little needle shake as I run the Goodparts S2 cam, and the valve timing is a bit advanced. It really runs great, zips to 4,000 rpm. Need to check the plugs next for mixture.
Perry
dklawson
Perry
Goodparts S2? I thought theirs were the GP2 or GP3 with Ted at TSI selling the S2?
I have the S2 in our GT6 and cannot get a vacuum reading nearly as high as yours. If you have a more or less smooth idle with 17" vacuum at 1000 then you have a healthy engine.
poolboy
There was a TSI S2 cam in my 73 TR6 when I bought it from "TR6 BILL".
Because of the overlap the vacuum wasn't steady or high..Seems like I had 13ish at 1100 rpms.
Not that I couldn't idle slower thereby perhaps obtaining a slightly higher manifold vacuum but I went for smoother rather than lumpy idle.
I have put the vacuum gauge on a few engines with the milder GoodParts GP2 cam and they seemed to run good with 15 in-Hg when idling under 1000 rpm.
dklawson
I remember emailing you about the S2 cam before I made my purchase. Like your experience, I remember a reading closer to 13" Hg. We have our idle set to somewhere between 900 and 1000. It idles well but with 13" Hg I never saw the need to hook up or use a vacuum gauge again.
gbtr6
You are correct, my mistake. It is the GP2. I imagine that has some overlap as well. It pulls strong and quick to 4,000-5,000. I love it.
Perry
Nelson Using timing light Spridgets 17
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
regularman Using a timing light Spridgets 8
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
F TR6 Timing adjustment Triumph 13
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
R TR2/3/3A Timing Triumph 3
F TR2/3/3A Ignition Timing - Again Triumph 11
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
B Engine timing Spridgets 8
tinman58 TR2/3/3A Timing ? Triumph 21
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
