I'm setting the timing on my new 1275 with a mild cam. The seller had recommended 28 degrees BTDC. I've set that at 2000 rpm. At 1000 rpm idle the advance drops to 10-12 degrees. I have a Petronix distributor with vacuum advance- these numbers are with the vacuum disconnected and sealed.
Should the advance drop so much with the reduction in rpm? This is my first time...
Thanks.
Thanks.
