TexasSprite
After a new set of carbs exhibited a bit of a stumble upon accelleration, I decided to make sure everything was OK with valve lash, timing, points, etc.
Valves were a bit loose, so no problem to fix that up. Points were pitted, so pulled the distributor out to replace them. Managed to short the wires while assembling, so chased that for a while. Got that fixed, put the distributor back in (it only would fit one way). I set the timing by guess and the car started and felt pretty good while driving, idle is a bit rough.
Here is the mystery. The timing marks are now 180 degrees off. The timing light picks them up, but on the opposite side of the pulley. How can this be? I don't think you can put the distributor in wrong because the slot and key is off center, and even if you could, I don't think the car would run. I am puzzled!
I never noticed this before, but the coil seems pretty hot to the touch. Is this normal? It is a Lucas Sport Coil.
