Daimlerdb18
This has probably been covered in other posts, but....when the static test lamp is used to set the timing a 7deg BTDC where will the timing mark show using a timing light? I set the timing using the lamp, but the timing light is showing a good 20 deg retarded???? Can this be right? Advancing the timing to show 7 deg btdc by timing light causes backfiring and hard starting. Just curious.
