Webb
My Equus advance timing light came in so I finally got to verify some numbers. Book says dwell should be 35 deg. plus or minus 3 deg. I got it fluctuating between 40 and 43 degrees. Now, it's either for every 2 degrees the dwell is off, the ignition timing gets off 1 degree, or vice-versa (for every 1 degree the dwell is off, the ignition timing gets off 2 degrees). Anyone know which way it goes? I read it, but cannot remember.
Also, found that the max advance I can get out of the distributor is 10 deg BTDC. Books calls for 12, but I think this could be remedied by getting the dwell set correctly.
Also, never use your tach to judge engine speed. This whole time I thought I'd been idling around 1000rpm. Nope....it reads 1000revs, but my timing light said 670 rpm!!
