TulsaFred
Putting the timing chain, gears, cover, damper, etc back together today after fixing leak (see previous thread on this).
I did not rotate engine while it has sat waiting for parts.
I think I remember rotating timing gears "dot to dot" before removing them.
Now putting it back, it appears that dot to dot on the timing gears is TDC of Piston #1 on the exhaust stroke, rather than the compression stroke.
Is this correct?
Just want to be sure before putting it all back together.
Fred
Is this correct?
Fred
Hi Guest!
