Darrell_Walker
TR3driver said:Seems excessive to me. I've removed tensioners with nearly 100,000 on them that didn't look any worse than that.
TR3driver said:I'd look the chain over carefully too, for sharp edges where it rides against the tensioner. The area looks kind of dry, too, unless you washed it all down with solvent before taking the photo. It should have all been dripping with oil when you took it apart. Might be you've got a lubrication problem. As I recall, there should be grooves in the front cam journal and holes in the bearing that lead out to the backside of the cam gear, which in turn has holes to let the oil flow to the timing chain.
