mt10flyer
For the 4th time now, my timing chain tensioner broke and wore a hole through the timing chain cover. I have replaced the pin, the tensioner each time. I was lucky enough to find a cover on EBAY the last time because the original looked like Swiss cheese.. The location where the tensioner makes contact with the cover needs to be smooth. Now there is wear there which probably keeps the tensioner (which is just spring steel really) from being able to flex properly. It then fails and rattles around until the chain shoves it though the cover...again. I heard it break while I was on the road and by the time I got home oil was leaking out the new hole like the Exxon Valdez.
There HAS to be a better solution to this. I had a MGB which had an acceptable, heavy duty tensioner in comparison. Of course that would be a relatively involved modification. I am still considering it. Anyone? Ideas?
