Trying to tune up my BJ8- it runs fine but I have never checked the timing. Under the strobe, the timing mark looks about 1” BTDC and holds steady. As soon as I dial in advance to the strobe gun, the timing mark jumps wildly (at least 3 inches, including to the other side of the mark). 600 RPM. Vacuum advance disconnected. Positive ground. Petronix Ignitor in an otherwise standard dizzy. Original style Lucas side entry cap. Can’t tell if my wires are solid core or not, but they are not original.
Tried with induction clip at both ends of the #1 wire (facing towards plug), gun hooked direct to the Healey battery, to an external battery and to the Healey generator with the same result. Tried this with two induction guns, one digital and one dialback-same result.
I don’t think it’s the mechanical advance, as the mark holds steady with 0 degrees advance in the gun. I’m questioning the wires, which are clearly old but I don’t want to be chasing my tail replacing the wrong parts. Any ideas on what may be causing this? Would buying a top entry cap and carbon wires be a smart next step? Thanks for any insights.
