timing again
I have been spraying PB Blaster and moving the cam. It is loosened up a little but it sticks on both ends of the travel. I sprayed it again with PBB and will try it again Monday.
I have been putting oil on the big screw pretty often. I guess the PO forgot.
Oh well, at least I am making progress.
Pete
I'm pretty sure that if you remove the big screw, the cam should slip off the shaft, so you can clean up in there. At least the 4 & 8 cylinder Lucas dizzies come apart that way.
