Tie Rods / Alignment
AH67AH
The track rod on my BJ8 is adjusted as far as it will go, and there is still 1/4" toe out. The steering arms are the correct part numbers and on the correct side, and bend toward the backing plates. The steering and idle arms also bend toward the outside. Everything looks perfect. Is there something I'm not thinking to check? All I can figure is that the track rod itself is too long, or the rod ends are incorrect. The track rod is 19 5/8" from tip to tip. When it bottoms out in the rod ends, there are still a couple threads showing past the nuts on each side. The rod ends are marked "CG3807". The dust caps on them say "ENGPRODUCS" and are made in England.
Can anyone tell me if these rod ends are correct? I don't want to shorten the rod if the ends are the problem.
Thanks for any input.
bdcvg
If You can measure the length of the tir rod end , I can compare it to 1 of Mine tomorrow. I'm pretty sure the 19 5/8 " is correct. Might be wrong tie rods
AH67AH
AH67AH
Thanks, the tie rods look like about 11 7/8" each, which I've been told is correct. The track rod ends are about 3 1/8" from center of the pin to end of the female threads. The female threads are 1 5/8" deep, which seems right since this is how long the threads beyond the lock nut are on the rod itself.
So either something is amiss elsewhere, or maybe the overall length of the rod ends aren't correct? I'm at a loss.
bdcvg
O.K. My ends are about 4 inches total end to end. I have about 11 7/8 " from center of track rod to end of tie rod.
kodpkd Adjustable Tie Rods Austin Healey 20
B TR4/4A Outer tie rods Triumph 8
K TR2/3/3A New Tie rods and Ends Triumph 3
R Tie rods zerk Austin Healey 32
T TR4/4A Question on inner tie-rods for TR4a Triumph 3
Basil EType Tie-rods Jaguar 2
M Steering Rack Inner Tie rods Spridgets 9
6 Whats the Proper Way to Remove Tie rods on AH BJ8? Austin Healey 17
T TR2/3/3A TR3 tie rods - made of precious metal or what? Triumph 6
Baz Quik Q on tie-rods Spridgets 28
tr6web TR6 Outer tie rods - TR6 Triumph 10
tr6web TR6 TR6 Steering rack - tie rods and more... Triumph 3
KVH Tie Rods and Ball Joints Triumph 5
W Correct Tie Rod Ends Spridgets 0
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
K TR2/3/3A Removal of tie rod end? Triumph 7
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
R TR2/3/3A Tie Member for TR-2 Triumph 2
F TR2/3/3A Tie member[front apron support tube] Triumph 11
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
M Hauling a Spridget - Proper tie down technique? Spridgets 15
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Feathers 289I inner tie rod end. TVR 0
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
Bruce Bowker For Sale MG Tie Clip MG Classifieds 1
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
steveg Tie Rod boots - urethane Austin Healey 22
Patrick67BJ8 Tie Downs for a BJ8 Austin Healey 17
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
W Inner Tie Rod Spridgets 3
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
D TR6 Tie-rod problem Triumph 4
S What do you use instead of tie wraps? Austin Healey 7
jlaird Tie down Spridgets 0
jlaird Rear tie downs for old folks Spridgets 20
M Tie rod end came apart easy - too easy? Spridgets 6
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
DornTRoriginal TR2/3/3A Tie Rod Adjustment Triumph 6
Sopwith_Camel Tie rod ends Spridgets 12
P Tightening Tie Rod Ends? Spridgets 4
H TR4/4A Tie Rod In Door - TR4 Triumph 5
