Working on replacing my rack boots today. First problem is lots of paint over the lock nut and threads. Which direction to turn to loosen it? I'm assuming it would be counter-clockwise if you were sitting on the rack looking at the tire.
Second question is how to get the tie rod end loose. I assume (again) that you take off the cotter pin and castle nut and it should drop out of the steering arm. Then you can unscrew it from the tie rod itself.
Do I have this right?
