hi all,
I am currently rebuilding my steering on my TR4, and I have some concerns about the way the tie rod lever is connected to the tie rod end. In the workshop manual, it is secured by a nyloc nut (#50 on the image).
I have a problem with it, when I try to fasten the nyloc nut, the screw from the rod end, which is freely rotating around its axle, prevents to tighten it correctly and I am concerned that the nut would eventually get loose. Am I being over-prudent here or do you share my concern ? If so, which solution would you advise ?
thanks,
Philippe-
thanks,
Philippe-
