Frank Canale
I started measuring for a lifting frame to lift the front half of the tub off the chassis. I removed the front apron, then removed the tie member. The tie member is a 1 inch square tube that supports the front apron. The one i removed is made of 1/16" wall aluminum tubing bowed to match the apron. The tube appears to be well made but seemed strange to be made of aluminum. My question , is this an original part or should it be a steel tube?
Frank
Frank
