sjuengst
The last time I took Muffy (Mk 1 BT7) out for a ride, I noticed a rythmic thunking noise (felt it in my seat too) which seemed correlated to the wheel RPM (as opposed to engine RPM). It sorta sounded like the driveshaft U-joint was hitting the frame. Yesterday, I put her up on jackstands and got under the car and looked around. Visual inspection of the driveshaft showed no sign of contact. Then, with the engine running and in gear, I felt the gearbox, OD, and differential, and could feel the thunk in the differential most of all. So it looks like I need to a tear-down of the chunk to see what's going on.
Here's my question: I'll be moving soon to a house about 10 miles away. Do you think it'll be ok to drive her there with this noise coming from the differential, or should I rent a trailer for this short trip? I'm not going to take her apart until she's safely in her new garage.
Thanks,
Stu
Thanks,
Stu
