Khlassic wheels
Hi ,
When I am depressing the clutch my idle decfease and car eventaully stall, I believe
I just need to replace thrust washers . I have seen on Youtube for a spitfire or TR4 that your just need to remove main bearing cap No2, use a copper wire an push the upper thrust washer around the journal of the crankshaft
https://www.youtube.com/watch?v=l1J28wSAPu8
I was wondering if I can do the same wiith my BJ8...Without taking the engine out, I don't think I need to remove crankshaft, I just need to remove oil sump, then oil pump then main cap bearing...I did it on my corvette 66 .
Thks
Thks
