Stewart
Ran into an issue while preping my overdrive for installation. The new throwout bearing does not fit with the clips into the arm however it will fit without the clips installed. On closer inspection the old bearing has enough material machined off to allow the clips to fit.
Was there a difference between the non od and od throwout bearings? This is for a 77 to 80 od trans.
