Through out bearing question
sim
Hi
Replacing the through out bushing on a 948 sprite with a active center bearing from Minia minia.
The new bearing has a plastic housing. Will this hold up to the heat that is in that area?
Or should i pop out the carbon bushing and have its housing machined to fit the new bearing. The out side edge will be on the thin side. Might be as thin as 1/16 of an inch. But I would trust a 1/16 piece of metal than the plastic.
the ears would be metal not plastic
Thanks
Sim
Ok Thanks
they must be working. Any idea how long it will last under normal use?
i havent installed mine yet, but i hear it will outlast the carbon throw out many times over.....it looks much stronger...z
I really think they last about the same maybe a little bit longer and smoother with the roller bearing!...a lot depends on how you drive as to how long either throw-out bearing will last!!
