G
Comming back from a church function doing about 65 and the throttle stuck wide open after accelerating. I turned the key off and fiddled w/ the pedal; lit it back off and it was still stuck. Did that a few times and finally killed it again and coasted to a turn-off by a street light.
I couldn't see anything. I used my phone for light ony to discover the throttle return spring is completley gone. I'm in the middle of nowhere in front of some rental units that can best be decribed as having questionable inhabitants.
I pulled the return spring off of the clutch and put in on the Weber. One of said inhabitants came out to see if he could render assistance. He was pretty cool. We talked a bit, thanked him for checking on me, told him God loves you and split.
The throttle is a little stiff but there is NO way it'll stick now !!! I'll put a better spring on it tommorrow.
