TR2/3/3A those metal button trim pieces tr3
sp53
I am having trouble with those metal button trim pieces that go on the end of the door trim on a tr3. I have the new capping in place with a new sponge rubber piece and cannot get the button to stay on. In part, because the rubber is stopping the little clip from grabbing hold inside the hole and because the button is cheap quality. Is there a different supplier other than the big 3 and what are some options?
martx-5
I remember having that problem also. I literally drilled out the rubber so I could get the button in.
CJD
I ruined one set...on the second (same poor quality), I used a deep socket that was exactly the OD of the button, contact cement, and shoved it straight in. So far it looks good and has not fallen out.
John
PeterK
John
ditto. I think it's mostly the contact cement holding mine though.
Geo Hahn
At least repro's are avilable. I recall years ago when small parts were scarce seeing a TR3 with Buffalo Nickels stuck in those ends.
Didn't look too bad as I recall.
A TR2/3/3A Those round fuel line clips Triumph 2
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
jlaird MGB For those who were excited with me. MG 2
tr6nitjulius General TR Those were the days Triumph 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
S TR2/3/3A those 3 white wires onto the ignition switch Triumph 3
S TR2/3/3A source for those little drain hoses Triumph 6
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
S TR2/3/3A On those old original coils Triumph 2
S TR2/3/3A Those chrome 4 bolts Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
NutmegCT Loosen those nuts! Restoration & Tools 5
HealeyRick Those Were the Days Austin Healey 11
Joe Reed General MG One of those "duh" moments... MG 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
alanjohnturner TR6 for those planning a new paint job Triumph 3
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
drooartz General Tech Check those brake hoses! MG 11
WillR For those thread nerds. Restoration & Tools 23
5 I used to own one of those Spridgets 6
S TR2/3/3A Those colored frames Triumph 4
M Those cork washers on either side of the kingpin... Spridgets 9
T TR2/3/3A Is there a good way to manage all those wires/connectors for headlights & park lights Triumph 9
Basil General MG For those who remember Tony Barnhill MG 25
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
CJD One of Those Days Triumph 15
P those infernal thrust washers Triumph 11
rick_ingram Check those splines! MG 7
L For those who know the difference Lotus 5
DrEntropy Where'd THOSE come from?!? Spotted 6
JohnnyMead Can't Get the Air Out of Those brakes! Triumph 8
Gundy Oh no...I've become one of those Spridgets 25
Got_All_4 Wedge Going to look at one of those yucky brown TR7's th Triumph 25
middie Those dashed darned brake calper bolts Spridgets 6
D One Of Those Nights Triumph 4
PATR8 It is just one of those weeks Triumph 8
B Those little tiny screws Triumph 4
Timd For those who like data and statistics Spridgets 6
K Those who switched back to points from petronixx.. Triumph 64
PatGalvin Tie Down Those Brake Lines to the Diff Triumph 4
zedvictor1 Those fender holes behind the RB Spridgets 6
roscoe One of those moments Austin Healey 0
T For those about to weld Triumph 3
pjsmetana Those darn Battery Terminals! Triumph 16
T OT - but for those of us doing body work scary Triumph 12
deadair TR2/3/3A For those who's TR3s are up on blocks Triumph 14
