So I have this little miss in the engine that I have been trying to figure out. I have put in new plugs, points, and condenser. Tried 3 coils and 2 condensers and 2 fuel pumps and plenty of fuel comes out of the tank; plus I have moved the timing up and down a little without any change in the stumble and have quality fuel in the tank from more than one gas station.
The miss or more like a stumble like too much fuel gets in or maybe not enough happens when I wide open throttle early on in 2 and 3 gear; I have not really tried 4th gear. I can punch it in first gear with no problem; I guess because the gear is so low; moreover, there is no ignition backfire. I can ease into the gas pedal and prevent the stumble in 2 and 3rd, but when I floor it early on in 2 and 3 it stumbles, but it will bust out of the stumble if I stay with it. The fuel mixture seems correct. I tried it a little lean and a little rich but no real difference.
My thoughts are worn out needles and jets or even the car is not totally up to operating temperature because of our cooler climate. I have a new radiator and tropical fan, a 160 sleeved thermostat and the temp is gauge is about a 1/8 before 185, so the car runs on the cool side, but that has never been a problem before and I have had that set up for years.
Before I get a new master SU kit or change the thermostat, I thought I would get some other opinions because I have lost my mind somewhere on this one. I cannot remember the last time I rebuilt the carbs and have been driving this car since 1971, so I know the car, but I am missing something.
