TR6 This frame was sectioned
Got_All_4
Surprise surprise. Looks like this 6 had some serious trouble. Frame looks like it was cut in half and welded together. Looks like a good job but will know once I get to measure it. The front shock tower support bar is another issue. I brought this up before and maybe has something to do with the sectioning. My hope is when I take the bolts and bar out that it snaps back where it is suppose to be. If not more measurements and possibly to a frame machine.
Got_All_4
Got_All_4
Plans are to strip the frame down and take it to have it dipped. They also do a e-coat. This frame had so much mud and grime you couldn't see the deterioration in the trailing arm cross member. Was hoping to have to not replace them. May cut one open and see what's inside.
CJD
Interesting...it may have had a donor front grafted in after a bad accident at some point.
Got_All_4
Got_All_4
ya that's what I'm thinking. There are some parts of the car body that are painted a bright metallic green under the signal red paint and the burgundy color on top of that. Where the rockers and the B post come together there is some heavy welding there. Patches or gussets too. I know the car was last driven in 1982 and don't know much more about it. For a 13 year old car to have that much paint work done has got to be fairly rare and leads me to think that something happened. Pulled the windshield off and that green paint was under the seal. So someone went to a lot of trouble to do a good paint job.
Deleted member 8987
or did a masterful job to hide what was underneath.....
Rut
Please be aware that e-coat is not UV stable and it will need to be scuffed and top coated.
Rut
Got_All_4
Got_All_4
Yes thanks. I have a good frame paint to go over and I sell a body cavity wax protector that will get sprayed into the frame when all repairs are done. I did my TR250 that way. Tilted it on one side then sprayed it in heavy so to run into the seams. After a couple of days to set up I flipped it over to the other side and did it the same way. Should be good longer then I will need it.
malbaby
That is some serious surface rust :chuncky:
Do you have plans on generally strengthening the chassis in other areas.
Got_All_4
Got_All_4
It's like that across the entire frame. However the pics makes it look worse then it is. My concerns are in the inside of the frame. I'll find that out once I get it stripped and stand it up and see what I can knock out of it.
D Spitfire Was the spitfire a body & frame car pre-73? Triumph 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
C TR2/3/3A Frame repair and value Triumph 2
J TR6 Repadding TR6 frame Triumph 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
S TR2/3/3A Placing the differential on the frame Triumph 4
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
S TR2/3/3A Frame repair. Triumph 47
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
ActionJackson Spitfire Frame Triumph 0
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Frame repaired? Triumph 6
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
7 Wedge Removing sunroof frame Triumph 5
Rut TR4/4A 4a frame modification Triumph 6
D General TR Frame repair - recommendations for NJ area Triumph 3
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
D TR2/3/3A Windshield frame fitting. Triumph 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
JamesD BJ8 Top Frame Bumpers Austin Healey 12
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
Healey Nut Seat Base Frame Position Austin Healey 4
P TR6 TR6 Frame Stiffener Triumph 4
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
C 100/6 BN4 Soft Top Frame Austin Healey 16
B Bent frame rails near BE front end Spridgets 2
F TR2/3/3A Bumper frame brackets Triumph 10
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
F TR2/3/3A Bumper bracket to frame question Triumph 7
P For Sale MG TF Ash Frame parts for sale MG Classifieds 0
D BJ7 Hood frame mounting plate Austin Healey 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
dbenichou289 TR2/3/3A top frame bracket Triumph 7
J Painting a Frame and Substructure Austin Healey 12
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
P BJ8 Frame Rust Options? Austin Healey 14
Rut TR6 TR6 frame Triumph 3
Got_All_4 TR6 Starting my frame restoration Triumph 32
