Hi Guest!
Looks like a good head gasket. Do you mean not much else will change in terms of horsepower and performance?buy a head gasket like this. Not much else will change.
Head Gasket Big Bore 87mm to 90mm LUCAS
Your One Stop Shop For All Your British Automotive Parts. Order Online Today! We Have The British Auto Parts That You Are Searching For. Order Today! No Sales Tax. Fast, Courteous Service. Rich Selections. Order Hard To Find Parts. Family Owned & Operated. Fast Shipping.bpnorthwest.com
OK i will go with 87mm. Upgrade the fuel in what way? KarlYou will have to upgrade the fuel due to better compression.(The 86 was always a factory option for the Tr3.)
I have always liked 87mm myself.When you do it, freshen up the low end and use the good bearings.
Also you can forget about using the hand crank only a gorilla can crank the larger pistols.
Mad dog
I see your point of not having to upgrade if it's not really necessary. I just had cylinder head work done and replaced the head gasket. That was the time to upgrade to the 87's but unfortunately I do not have a proper shop to do the work and I'm getting too old to crawl underneath and tap out the old liners. Anyway the car is running fine for the cool Fall weather we are having here so I'm just going to enjoy the ride for now. One thing I need to do next year is to replace the timing chain. Pretty sure it's worn and making noise. A fellow club member gave me a set of new gears from a project car he never used so I just need the chain. I'm fairly confident I can tackle this job but I'm a little intimidated about getting the chain set properly and not have it one tooth out? Any thoughts?I absolutely agree with Tom (TFB). We have a saying in the aerospace industry: "better" is the enemy of "good enough."
Thanks for he info.It's not just one tooth. The camshaft is timed to within 1/4 tooth. The procedure isn't simple and I would hate to have to do it with the engine in the car. As a minimum, I think it would be necessary to remove the radiator and grille. (I'm thinking TR4A here; not sure about the TR3).\
FWIW, here is my experience; > Engine Rebuild <
I suggest anyone getting new liner and piston set measure carefully before install,not taking for granted that the manufacturer has got the fit right.As mentioned above, the one problem I had with my last set of liners was the piston rings. The oil ring was the set of two thin springs, and a wavy piece in the middle. I have not had luck with that type of oil ring. I also think the liner sets have too much ring gap as sent from whatever factory they come from.
So it's not as complicated as I've been led to believe? That's good to know. Not clear on what you mean by "having the old and new gears facing up" but i guess if I had them in front of me I'd see what you mean. Where did you buy your chain the last time you replaced one? Is it better to get a chain where there is one link that separates? KarlI simply copied the marks from my old gears. Easy if you make sure the old and new gears are facing the same way up, exactly line up the bolt holes on the cam gear (just put bolts thru the holes thru both gears), and make sure the teeth are exactly aligned. Crank gear is easy, only a few teeth so it is hard to screw up.
Bob
