Thinking of some tunes....
bugedd
I am considering putting in a stereo in the bugeye, something classic in style but Ipod capable. Any suggestions from those who have tried this?
drooartz
Were it me, I'd probably mount a small amp somewhere out of sight so there'd be no visible radio. I've thought about adding such a system to my MGB -- all you'd need is a jack somewhere and the whole thing stays hidden.
Keith_M
I have also been thinking of how I might add an unobtrusive but modern stereo to my BT7. One option would be to get a set of bluetooth speakers that could be mounted in a variety of ways depending on the car. These speakers come in all shapes and sizes and are not particularly expensive. You could send music from any bluetooth enabled device (ipod, phone, etc) without the need for separate amp. I've seen several nice versions that run on 12V, but I'd be worried about the whole positive-negative ground thing.
Anybody else thought-of or tried this route?
Keith
Morris
Keith, I think the bluetooth idea is really good. I think the challenge will be finding speakers that are loud enough. However, an intrepid fellow with a soldering iron could probably figure out how to pipe the bluetooth speaker output to a conventional auto amp.
Keith_M
Hadn't thought of that aspect (which is surprising given the engine and wind noise in my Healey!). I suppose I will now have to trot down to my local electronics store and see how loud they can be. Another advantage is that many of these speakers are rated for "marine" or "outdoor" use, which describes the conditions in my car exactly.
AvionicsTech
This is actually my plan for the '69. If all you want is to be able to listen to an MP3 player, and have no desire for actual AM/FM radio, this would be the best way to go about listening to tunes while keeping a "classic" look. Nothing more classic in a bugeye than no visible radio at all.
David_Doan
You can buy Bluetooth adapters, no hacking required - unless you want to :smile:
Keith_M
This is an old thread, but I thought I'd update it in case others are still looking for solutions. We all know the problems associated with putting tunes in a Healey. In my case, the car is positive ground, which limits my choices in stereo equipment. Although I know that positive ground "retro" radios are available, there just didn't seem to be a good spot to mount one and I wasn't sure it would look all that good even if I found a spot.
In an earlier post I brought up the idea of using bluetooth speakers,but there was some concern expressed that they might not be loud enough. After some research, I purchased a set of these speakers for $55 -- Creative D100. The speakers connect easily to my smartphone and are powered by 4 AA batteries, so there's no electrical connection to the car. Battery life is supposed to be 25 hours, and I have at least 5 hours on my first set of batteries.
The speakers look pretty good sitting on the tranny tunnel, and I used a little velcro to keep them from sliding off every time I took a fast corner. They can be easily removed to prevent theft or to use them for other purposes. And they are loud. Loud enough to be heard at 60 mph with the top down, which is pretty remarkable. The volume can be easily adjusted on the front of the unit, or from the smartphone or whatever bluetooth player you're using.
So far, I'm pretty happy with this solution. It required no modifications to the car, it was relatively cheap, and it sounds pretty good (except when my son plays rap through it).
Sopwith_Camel
I just got a retro sound model 2 its Ipad and iphone compatible
now i just have to stick it in the jag. running a sony in the spridget works ok
my big tip is get boat speakers because they are engineered to get wet!
steve
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
G Thinking About My First Bugeye Spridgets 20
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
B thinking of buying a 1967 triumph 2000 Triumph 22
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M Thinking about buying a 52 MG TD Spridgets 2
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
M wishfull thinking? Triumph 10
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
JPSmit So, I was just thinking Spridgets 5
A 59 Bugeye. . .Thinking of Selling Spridgets 7
T I am thinking of selling...... Spridgets 17
DeltaAir423 I got to thinking the other day Triumph 4
T thinking caps required Triumph 59
G Thinking about the stock fan Triumph 7
B Thinking about heat shielding options. Spridgets 9
