Thinking Of A Discovery SE7
jhorton3
So I've been toying with the idea of getting a Land Rover Discovery II SE7 to replace my 99 Jeep Wrangler. I'm looking for resources that tell what I need to be looking for when buying a used Rover, what kind of maintenance I can expect, and the prices. Any known resources that you know of?
LarryK
You will probably look at the 2004 DII, as they were the best in quality and have less issues. If you are adapt at OBDII diagnostics and /or laptop capabilities there are loads of downloads to diagnosis problems for the DIY person. I have had a D1 for 10 years, parts can be expensive, but there are quite a few guys that broker them and are reasonable in parts. Main issues are body electronics and suspension electronics and the ABS, hard to diagnosis without the laptop downloads. I had a P38 Range for 5 years, traded with a dropped sleeve ( 4.6 Gems engine ) 94 for might have the BMW or Jag V-8 don't remember as I have older ones.Dealer costs are quite high, so alternate independent shops are best it your are not DIY. For further info: lrrforums.com and discoweb.org, 2 of the better sites and RangeRovers.net a full worldwide site for repairs and parts, lots of info. If the pound to dollar would go down I would still have my P38 Range ( traded for a Ford 150 4X4 > not the same ). By the way, you have a fabulous Rover shop just North and East of Atlanta ( Bear Rovers , can't remember exactly, might google and see, good rep on sites.)
jhorton3
jhorton3
Thanks for the information Larry. I've bookmarked those resources and will use them in my research. I had heard that parts and labor were really high priced. I read an article about steering links that scared me a bit, so I thought I'd better do some more research. I did find Bear Valley Rover and it's not that far away from my office. I stopped by and they had one on the lot that I just viewed from the outside. Sometime soon I need to schedule a test drive to see if this is a vehicle I want to pursue.
LarryK
Steering links are only a problem with high off-road use. If maintained for off-road, I cannot see a reason for worry. I have the original steering on my 96 D1 strong and in good shape. Most problems occur with neglect and misuse. These are strong trucks. There are a lot of aftermarket protection accessories for off-road, just need a big pocket book.
jhorton3
jhorton3
Thanks for clearing up the steering issue. The other piece to that article was the need to replace head gaskets after 80K. Is that true?
LarryK
80-100K normal maintenance on all aluminum engines. Not a hard job, just dirty. DIY for under $150.
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
G Thinking About My First Bugeye Spridgets 20
bugedd Thinking of some tunes.... Spridgets 10
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
B thinking of buying a 1967 triumph 2000 Triumph 22
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M Thinking about buying a 52 MG TD Spridgets 2
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
M wishfull thinking? Triumph 10
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
JPSmit So, I was just thinking Spridgets 5
A 59 Bugeye. . .Thinking of Selling Spridgets 7
T I am thinking of selling...... Spridgets 17
DeltaAir423 I got to thinking the other day Triumph 4
T thinking caps required Triumph 59
G Thinking about the stock fan Triumph 7
B Thinking about heat shielding options. Spridgets 9
