thinking caps required
T
Tinster
My car is dead from rust in tank. Refurbished once
but cannot purchase liner chemicals on-island. Can't
find a radiator shop to boil the tank, either.
I have stripped out and cleaned everything from the carb
bowls, lines, filter, pump, etc back to the tank.
The tank is pulled and on the ground like a great whale.
The Mrs, rightfully so, states no more cash infusion.
Homeland Security does not allow me to import Eastwood products.
A new $gazillion fuel tank out of the question.
I;m thinking maybe a bladder tank might work.
Or maybe 1/4" Lexan and industrial epoxy seams.
Or maybe just rig up a 5 gallon DOT plastic tank in the trunk.
open to suggestions. Here's what came out of my tank into a
coffee filter flushed with a pint of water.
d
Bingo! I believe Ray's found the answer for you, Dale. Clean the tank out as best you can; flush it out well, and follow up with a good rinsing with vinegar (yes, vinegar - do a google search on vinegar and rust if you don't believe). Rinse out with water again and dry it out by leaving it out in the hot Puerto Rican sun. Then coat it with the POR stuff and let Amos do his thing again!
Dale,
Why not get someone as close to you as possible on the mainland & ship it to you?
Is there any reason why someone on this forum could`nt buy the stuff for you & ship it to you?? Is customs or something like that a problem?
Russ
Dale: A few more suggestions.
1. W.W. Grainger now has a PR Branch. They may have access to some of the supplies you need. Ask for sloshing sealer as used by general aviation for sealing airplane gas tanks.
Cataño Location
Grainger Caribe, Inc.
Zona Industrial Vista del Morro
Avenida Boulevard, Lote #2
Cataño, PR 00962
Phone: 787-275-3500
Fax: 787-275-3536
2. If there is a general aviation clique on the island they may know where you can get these supplies.
3. Rustoleum sells a 2-part epoxy sealant (paint) for sealing garage floors. This should be available at the despot. However before you use this product I would give rustoleum a call and ask if this would hold up under its intended use.
Dale,
What would be the cost of shipping your tank to a BCF friend in the USA and having them treat it with some Eastwood products and ship it back to you?
When you have fixed/repaired tank, think about putting in a marine fuel filter to help keep the moisture out of the fuel lines. Mercruiser and Volvo Penta or something from the diesel powered boats.
Dale, take the tank out (which I think you already have) and place about 2 or 3 foot-long pieces of heavy chain in the top and pay someone to shake it vigorously for a few hours. This will bust out the rust and you can go from there with the above coating suggestions.
BILL!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I already banged and clanged with
chains, nails, barbed wire, whips, iron maidens.
handcuffs, assorted nuts and bolts and acid for a
solid 4 hours.
Proplem I can't purchase coatings here and DPO Pedro's
rust comes
back.
I need to make me home grown plasctic fuel tank.
f
EVEN TINSTER KNOWS THIS IS BAD LOOKING GASOLINE!
Go to your local West Marine, 2 on Island, and ask them if they have some kind of a tank sealant. If not who can they recommend? In the meantime get some rust mort and pour some in and slosh it around and then pour it out . Then add water to neutralize it. Put everything back together until you found the tank sealant and do it as a "winter" project. You got 1500 miles out of Amos,you'll do it again. And get rid of at least 1 filter.
Stainless steel pony keg can be made to work. 7.5 gallons. I had a standard 15 gallon keg on a dune buggy I built years ago. They were easy to come back then. After we drank the beer, all it cost us was the deposit..
Cataño Location
Cataño, PR 00962
Phone: 787-275-3500
Fax: 787-275-3536
There's the answer....where's Cataño, PR?
Victoria British had a price reduction a while back on new gas tanks. The price literally went down 40 percent.
For the hassle and peace of mind, maybe consider talking the boss into that sort of cash infusion.
You could sell it as a safety thing. After all, the gas tank is right above the tail pipes.
I like POR 15, and I've heard good stories. But it's messy, and not all that cheap to buy. And it doesn't store all that well. And you said you couldn't get it.
All said, whatever you do, don't toss out that old tank. I'd keep it and restore at the right time in the future. It's just me, but when I had holes in my tank I didn't want to rely entirely on POR15 or any product. Too timid I guess, and I had kids in college. Good luck either way.
Somebody on the island can bend metal (aside from the occasional hurricane).
Take them your tank and ask them to reproduce it for you in, say aluminium.
Now, the trick is to barter the work for something you have they want.
The general avation community on P.R. is pretty good (at least when I was there...).
Go to the airport and go to the G.A. hangars (the small ones) on a weekend (important). Guys should be milling about working on their planes. Explain your dilemma to them (have the tank in you trunk!) and see if they can help you.
Contact Juan Jiménez in San Juan via his web site : https://www.bd5.com/
Trust me, this guy has used/is using sloshing compound!
I sloshed my BD-5 tanks (thats the wings!) twice before they stopped leaking.
Good Luck
P.S. I'd be willing to receive your tank here and fix it up then send it back to you all happy...
Or, if you don't want to go the Grainger route, pull the tank & fill it with muriatic acid & let it sit while it does its thing...then drain...then punch a 1" hole in the lowest point of the tank with a hole saw & flush it so everything runs out that hole (you can have the plug welded back in afterwards.
This isn't that big of a big deal, Dale.
& I'll check Monday to see if VB has them at a good price that I can beat!
First.....does your wife know that she's missing a glass from the kitchen cupboard? But seriously.....I order POR-15 products from the POR Outlet on eBay. Here's a listing for the gas tank product https://tinyurl.com/5fefc3 They ship to the USA and last I checked Puerto Rico still qualifies. $30 with shipping.
Oops.....sorry but they only ship to the "lower 48"... no Alaska, PR or Hawaii.
tony barnhill There's the answer....where's Cataño said:
Do you have any memory left of sampling 25 different kinds
of rum at the Bacardi plant in Cataño, PR?
Ah ha!!
I didn't think so. It's right around the corner from the
house, maybe 2 miles.
<span style="color: #990000">Maybe this is all mumbo jumbo marketing. I never saw gasoiline cut into exterior latex wall paint once it was set up. Maybe I should clean the tank again and then dump in a gallon of latext and let it cure a few days?
Anyone see a downside to this attempt with high gloss latex?
dale</span>
