Thinking About My First Bugeye
genep52
Hello everybody. Am thinking about buying my first Bugeye -- something to tool around town in on the weekends only as a second car. Don't need a show car, just something that sounds reliable and decently priced. Saw this one on eBay (https://bit.ly/1dnahzl) and it might be what I'm looking for. Any thoughts on the car or what the bid should be?
bugedd
A Buy It Now for $9500 seems a bit steep to me, and for a driver I'd want a 1275 with at least a ribcase, if not a Datsun trans, and front disc brakes. I would think you could find that out there for that price.
aeronca65t
The guy that owns Minimania has one with a Datsun trans for $6500
JPSmit
Welcome - and, excellent choice! Probably worth spending a bit of time around here figuring out what you want/need (assuming you don't already) - not sure how knowledgeable you are? Might also be worth joining a local club as they often have very good deals come up - with "known" cars. Ebay doesn't seem like the choice it seems to be.
drooartz
A Bugeye is a great car, possibly my favorite, so great choice. As to that one, really hard to say without seeing it in person. A lot depends on body condition. Mechanicals are simple, but rust is always a complication.
There are plenty around, though, so no need to rush into any one car.
Jim_Gruber
Steve appears new floors were installed but looks to me welds not finished. Is that what you are seeing
Jim_Gruber
Other thing I didn't like engine compartment not same as body color. 6-7 BE's on eBay right now and the cars commanding bigger $ all have finished engine compartments.
AN5Sprite
Floors look to have a thick coating of some form of spackle on the underside. Notice how every raised or lowered stamped area is filled in flat... Doesn't look like paint or undercoating to me. Looks like trouble.
I'm also turned off by the black under-bonnet. Not fun to live with and not easy to fix.
Gerard
Agree... looks like bondo to me. Here's what a correct floor looks like. I also detest cars w/black engine bays. unless that's how they came from the factory (many American cars)
BlueMax
I thought original floors were painted in a red iron oxide primer as well the boot not a colored bead liner?
Jim_Gruber
I agree about trouble underneath whatever that is that has been applied to the floors. Was tough for me to see from my cell phone. Under carriage doesn't need something to trap moisture and cause rust.
bug_sixty
I wouldn't necessarily go to the dark side on this one...My BE has the OEM floors... before my ownership the lifting of the car by whomever was done at various times under the foot area leaving huge dents... So the bondo deal here could simply be a quick fix to make the underside more eye appealing. FYI, I just left mine dented because at the time of my restore the boards weren't available.. The metal was stretched too... So, I just bead blasted so on and painted with Imron...
Jim_Gruber
Yes but in that one photo there appears to be a large crack in whatever material is under there. A cavity to hold and trap water = rust. These cars rust soon enough, might as well not create an opportunity for that to happen by trapping water in there.
Gerard
Ummm, I think the context was the shape of the floor pans, not the finish... :chargrined:
macsprite
Steve, Jim, Gerard et al, let me respond, since it is my Bugeye in question.
The floors do indeed have a seal coating on them, not a bad idea really with the condition of roads in some parts of the country. The welds are complete. The only floor holes are the correct holes for the seats and inside seat belt mounts (since there was no tunnel mounting points). The photo that you are referring to is of the front footwell section of the floors only, which were replaced with a flat panel, not the stamped footwell. The rear floors have all the correct stamped channels and are in great shape. Do you really think someone would go to the trouble and fill these ? LOL. I'lll take some more floor shots tomorrow and add them to Spritespot. See the inside before carpets pics of the floors on Spritespot. The floors are 100% solid and the remainder of the car is also rust free. I have detailed that there have been other rust repairs - new spring hangers and outer rockers that I can see, and a few other patches in the wheel arch area. These are shown in the photos on Spritespot. How many sellers do you know that would give this full disclosure? Nothing to hide here.
The black under bonnet seems to be an American thing, why do you guys do that ? I had never seen this on a Sprite from other countries but see it often on cars here in the US. It would not be my choice on a full restoration, but as I have explained to Gene, the car was 80% complete when I purchased it. I have corrected the things that were wrong and finished it without starting over. I have also indicated that there are some poor paint match sections and that it is a good 10 footer.
The car has many, many new parts (down to the nut and bolt level) and is correct with a few minor exceptions, which you may or may not be able to pick. See if you can, if you like a challenge ! I have been totally up front about the condition of the car. It is a solid Bugeye with an original 948, smooth case and new drum brakes all round. It is not and will never be a concourse car. If it had a 1275, ribcase, disc brakes etc, it would be worth more $$$, like the $12-15K cars often seen on eBay and other sites. It is not like some of the crap cars I see sell on there for $6-7K, its somewhere in between.
Regards
Lew
Jim_Gruber
Lew\,
Thanks for the clarification. Yes lots of really good things going for this car. Bugsy I was like that for me. Would never be a Trophy Winner but a solid everyday sriver that was well sorted after 10+ years of ownership and constant tinkering as needed to always make it better. Hope you get your asking price and I will ammend my previous comments.
A 59 Bugeye. . .Thinking of Selling Spridgets 7
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
bugedd Thinking of some tunes.... Spridgets 10
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
B thinking of buying a 1967 triumph 2000 Triumph 22
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M Thinking about buying a 52 MG TD Spridgets 2
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
M wishfull thinking? Triumph 10
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
JPSmit So, I was just thinking Spridgets 5
T I am thinking of selling...... Spridgets 17
DeltaAir423 I got to thinking the other day Triumph 4
T thinking caps required Triumph 59
G Thinking about the stock fan Triumph 7
B Thinking about heat shielding options. Spridgets 9
