Thinking about buying a 52 MG TD
MichaelJones
Hi All:
I have had a 76 midget for several years (my entry car) and am thinking about an older car. I've found a 52 TD that was restored in 79 and has been in storage for 12 years. My question is this: What are the basic steps I'll need to take to get it started and assess the running condition? Posting here because I've received lots of good advice on my Midget in the past.
Gerard
Hi Michael,
Fluids are the first things to consider. If gasoline was left in the tank and lines, that will be your biggest problem as it will have jelled or solidified by now. That means cleaning out the tank, flushing the fuel lines and probably disassembling and cleaning the cars.
I'm not real familiar with the XPAG engines, so I can't comment in specifics there, but make sure you squirt some MMO in the cylinders before you try to turn it over, even by hand. I find that British cars stored indoors usually don't seize up, but any oil would have long ago drained back to the pan, so make sure you have oil pressure before you try to fire it.
The cooling system will need to be flushed, especially if there are any aluminum components. I'd remove and check that the thermostat will open or just put in a new one. Check any rubber hoses (fuel, brake, water) for cracks or signs of failure.
Last, but not least, brake hydraulics are almost certain to be frozen from sitting for so many years. you will almost certainly need to rebuild or replace the MC and wheel cylinders. I have a good source for restoring these if you need.
All of this assumes it was parked and no sort of maintenance or precautions were taken over the years.
That should get you started (no pun intended...:smile:
I have a '54 TD that I service occasionally, so I'm familiar with a few other things if you decide to get it.
Look in the archives for "Awakening a Sleeping B". Most of that will be applicable to the TD and should cover most of the potential issues. It's what I plan on following for my 56 Jag when the time comes. Good luck.....and post PICTURES! :laugh:
B thinking of buying a 1967 triumph 2000 Triumph 22
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
Bruce_B Spitfire Thinking of buying a 1969 Spitfire...but..... Triumph 8
RobT Thinking of buying a Lotus Europa S2... Am I nuts? Lotus 9
S Thinking of buying a 1960 Austin Healey- Questions Austin Healey 6
D MGB-GT Thinking of Buying a '67 MGBGT MG 8
Webb Sledge TR6 Thinking of buying this TR6 Triumph 11
t8nwa thinking of buying a classic - what to look for? British Motor Corp 2
Basil Thinking about buying a Mini British Motor Corp 18
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
G Thinking About My First Bugeye Spridgets 20
bugedd Thinking of some tunes.... Spridgets 10
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
M wishfull thinking? Triumph 10
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
