Think I 'Slammed" Her a Bit Much...
I would be very interested in your feedback on that tire size choice. They are a bit wide for the rims and a very low profile which I would expect to raise heck with the rear suspension. Please report back when you have driven it a bit!
Tony,
If you are planning to carry on with vintage / historic racing in this car it might be a good idea to check the ride height rules and tire rules in the area you will be racing. I found that every sanctioning body has a different set of rules. One rule that affects vintage here is a maximum of 1" lower than stock height. You obviously don't have a problem with removing and modifying suspension (or anything for that matter) but if you could set up now to match your future vintage set-up, you could save yourself a lot of do-overs.
Think I 'Slammed" Her a Bit Much [NEW PHOTOS]
Well, as of now, she's higher (25" front & rear from floor to top of trim line)...all 7 leafs of the original spring are back under her & the lowering blocks I built are back in the almuminum scrap pile...just 'restacking' the rear springs achieved the effect I wanted....& now she's also at the proper height for historic racing!
Oops, forgot photos:
Re: Think I 'Slammed" Her a Bit Much [NEW PHOTOS]
Surely looks better anyway.
Hey, you misspelled Hooters. She look fantastic Tony. Can't wait to hear how you do in the race.
GO /ubbthreads/images/graemlins/lol.gifTONY /ubbthreads/images/graemlins/lol.gif
Hey, I didn't realize you were using Bill Guzman's kit. Nice! I met him last year at his house in Camarillo. Very nice guy!
Beware Tony,
As you know I have 2 MG V8's the red one I had the chance to take it around the track in Sebring.At the time the car was level, just like your GT. At around 110 mph the front started to lift and the steering became extremly light, in fact it was down right scary. With fuel in the tank, and rear wheel drive the front will rise, not much but it will rise under accelaration. To cure the problem I raised the back by 3/4" , and the problem did not return, you could do this or lower the front to create a wedge effect. I also did the same on the Silver Lady and have never had trouble although I do have a differant spoiler on this car than on the red one which has the same spoiler as your race car.
Good luck.
Mike Cook
Silver Lady 4.0 ltr V8
Vroom 3.5 ltr V8
110, my god Tony, think of your grandchildren. What you really need is a quickchange raiseing and lowering job. How about air lifts or something along that line? Tis my understanding that this vehicle must compete in different kinds of events? High and low speed and concours.
I got up this morning, looked at the photos, & decided I didn't like all those decals all over her...so, I took most of them off!
Shucks, thought they were sponcers. hehe.
Hey, Doc - what's the rule: understeer lower the rear; oversteer lower the front?
Mike - how'd you raise her? Did you add another leaf to the top of the spring instead of to the bottom?
[ QUOTE ]
[/ QUOTE ]
I was wondering when you were gonna do that - hehehe.
As far as understeer or oversteer... I'd stick with level and try it out... then tune from there. At low speeds (autox for example), you'll want a nice balnce of both understeer and oversteer - adjustable by the throttle... The only real problems with one end being higher comes at high speeds (80mph plus)... The rear a tad high will cause a suction effect under the rear of the car giving downforce, keeping the car on the road better... The front a tad high (or sometimes level) at those speeds will cause air pressure build up under the front of the car giving lift... You'll lose steering effectiveness at speeds over 75-80mph... Not good if you want to turn at that speed.
I hope my description helps here.
Like I said I think, rear air shocks so you can adjust for type of driveing you will be doing.
$$$$ for GRM effort... not an option, methinks. But a good solution if "open rules" were in effect.
If you can get it level, Tony, I'd be inclined to agree with Kenny: start from there, and do some "emperical" testing... Thrash it around that airstrip and fiddle the tire pressures a bit first to see if you WANT more over/understeer. Then start juggling spring leaves, etc.
Just a thought.
Yeah, you're right - of course....I've got her as level as I can right now (1/2" difference front-to-rear).....think I'll want the front a bit lower...but won't know until I thrash her around...next is pulling the dash to get rid of some of the steering column braces....
Tony.
The way I raised the back was by using a larger "cheese wedge" between the springs and the axle. Are you using this part on your car? it does a great job keeping the prop level under acceleration and helps reduce spring curling.
I am using a 3 degree wedge on the Silver Lady. Looking at your car it looks as though the front could be lowered to acheive the angled body effect that would level out under acceleration. Another question, if you are using this car on tight courses what degree of negative camber are you using?
Regards
Mike Cook
VROOM 3.5 ltr V8
Lowered the front of a bugeye long ago. Used plymouth springs and cut a turn off of them. Really improved the handeling in Autocross all of a sudden I could stear with the throtle.
Mike - I induced 2-degrees into rear end, same as front end....Dick Leuning is coming down next week to look her over & make suggestions...holding off on suspension until then...he'll know what to do
