jlaird
The leaks. There is a large bolt and a tapered washer with a cork gasket/seal on the bottom of the carb. That's where the leaks were comming from. Went back to cork seal rather than O ring as the o rings were not quite the right size it seems and I could not find a really right one. It needs to seal around the thread area thus the taper to force it in against the threads/bolt thing.
We shall see but has been holding for several hours now.
Hi Guest!
