TR6 Thermostatic vacuum switch
Ribbs
More curious than anything; does the thermostatic vacuum switch allow vacuum to reach the retard unit at the distributor when the radiator water is cold or once the water is warm? The switch was already removed from my 1973 TR6 when I took ownership, with the vacuum tube going straight from the rear carb to the retard unit now.
poolboy
There is a waxstat valve within the Thermostatic Vacuum Switch which prevented the vacuum from reaching the distributor's vacuum retard module when the coolant temperature reached the waxstat setting of over 200*F.
The effect was an increase in idle speed, fan speed and coolant circulation strictly due to the advance in ignition timing.
R
Ribbs
Thank you poolboy. I wonder then, without the thermostatic vacuum switch present if I wouldn't be better off just disabling the vacuum retard unit altogether. I believe that where the vacuum port is located the retarding action goes away as soon as the throttle comes off idle anyway. In that case would I leave timing at 4° BTDC at idle?
I do plan to send my distributor into BVU this winter for an overhaul including recurving mechanical advance and the addition of their advance module.
poolboy
Retarding the ignition at idle is (was) an attempt to reduce emissions when the engine is idling...you can read a little on it here for the theory and nature of the emissions it's attempting to control.
http://www.georgiajag.com/Documents/Vacuum Advance versus Vacuum Retard.htm
If you disable it as many of us do, the ignition timing will advance as much as 14* to 16* depending upon the module, which will put the spark somewhere within the BTDC marks on your damper...10 to 12* BTDC at idle with a disabled retard perhaps.
Rob @ BVU will give you his recommendation for setting the timing with reference to the damper marks once he installs the Vacuum advance.
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
B TR6 Vacuum retard late TR6 Triumph 4
