BugeyeNJ58
My 59 BE, 1275 engine started to overheat the other guy, got it home in time. Went to check the thermostat and it was definitely defunct. Removed it, went for short drive and water temp was fine.
Looking in Moss catalog, they sell a blanking sleeve to put into the spot where a thermostat would go, and don't recommend driving without a thermo. if you don't use this sleeve?
Is that true? Seems like in hot weather, I don't need the water to not go into the radiator at startup....engine warms up quickly.
