All: I know, the title should provoke a "Well of course, dummy..", but here's the issue: I'm overhauling the cooling system this week and of course a new thermostat is on the menu. I pulled out the old one, a "wax type" ie non-bellows version (fyi, I have a '66 BJ-8 engine [29K] in my '62 BT-7). It had a standard type of gasket which I of course scraped off. I'm interested in trying a bellows type thermostat and bought the Moss version just to experiment. Question: The gasket that is recommeded, and which is pictured in the AH shop manual as a "joint washer," is a very thin diameter ring about 2" across or so. Not a usual paper type gasket. Seems like the little washer allows the therostat housing to rest right on the cylinder head, ie metal-to-metal contact, but slipping a standard gasket in means the bellows thermostat will not fit in at all, and it fits poorly on top. Should I rely on the joint washer and seal the housing with Permatex? Use the washer and a paper gasket (which is not mentioned in the shop manual, btw..)Recommendations? Many thanks,
-Tom
-Tom
