thespartan0199
Hi All,
My thermostat failed and apparently I don't know what I'm doing because it was immediately seeping water at the housing slightly after I changed it.
I've never touched this on my car. When I took it apart it had the "original style" thermostat in there, 30+ years old. I decided to change with modern style.
I have the following new parts that I reassembled:
Brass sleeve
Small "thermostat gasket"
thermostat
thermostat housing gasket
What I read recommends the use of the sleeve; is this common practice?
What order should the parts and gaskets be assembled in? I put the small thermostat gasket under the brass sleeve which I thought made sense, but looking back now I have no idea if I assembled the parts and gaskets in the optimum order.
At this point I just want it to not leak.
1961 Austin Healey 3000
Thanks!
Brass sleeve
thermostat
Thanks!
