LuckyLuke
The original heat shield on an Austin Healey looks like it is made from Asbestos. My intention was to replace it with modern non dangerous materials. The new ones from Moss look very much like Hardie Backerboard from Home Depot . So I did a little investigation. First of all the Hardie Backerboard has zero flammability based on the spec sheet on their Website. https://www.jameshardie.com. So it should be good for thermal protection close to the exhaust. When I tried to brake a corner it was much more rigid than the original Asbestos version. So I made a template from the original and disposed the asbestos (check the local law about disposing asbestos!). The 1/4 “ Hardie Plank from Home Depot was easy to cut with a Jigsaw and the holes were drilled with a conventional drill. When I mounted it under the car I was surprised how strong the this stuff is. The final result was satisfactory, the material looks like the original.
The Hardie board that is normally used as base for tiling comes in 3'x 5' sheet. I will use the plenty rest to protect more surface in the exhaust area from heat and maybe to finish my bathroom
