Yes, but be carefull you have enough gap at the front edge so the door won't hit the fender when it pivots in.
If I remove .0625 (1/16 inch) from the door side of both hinges, will I increase the door gap at the B pillar by 1/16" and decrease the door gap at the front wing by 1/16"? Also, what will happen at the gap to the scuttle?
Good grief. 1/16" ?? These cars were never built to those standards originally!
You can easily get more adjustment than that, just by sticking a 2x4 in the jamb and prying on the almost-closed door. With the early hinges, I'd guess it's the surface of the A-post and the leading edge of the door that deforms, but it doesn't really matter. Just don't go too far.
