NickMorgan
Well, I have to eat humble pie.
Here I was telling Tom (Nutmeg) how easily my choke cable pulled out and discussing with Harry and Don the position of the connecting rod, where various parts are connected and how far the fast idle cam moves on my car.
I was trying to advise Tom on what should happen when a little spark went off in my brain. My TR3 has been a bit reluctant to start from cold. I would pump the fuel through by hand, pull the choke out its full one and a half inches and press the starter button for about ten seconds. Then I would try again, and again. Eventually it would fire once and stop. After another couple of tries it would eventually start (if the battery lasted long enough).
I went out to the garage to take a picture for Tom and noticed that my choke lever wasn't as far back as I expected. To cut this long story short. My choke was also not working properly and I followed the advice already posted for Tom, dismantled the carbs and put grease on the cork washers and glands.
And now ... my choke knob pulls out a full two inches, both jets lower and the car starts almost as soon as the starter moves the fly-wheel.
Thank you British Car Forum. You have just solved a problem I didn't know I had!!
