Tinkerman
Happy Veterans Day and thanks to all you Vets out there!
Today a friend and I did the finish assembly on the transmission. All the gears except the input shaft and its gear were already in the box. We turned the box upside down and fiddled the lay gears into position. We then spent the next 10 min wiggling the lay shaft and the main shaft trying to get the lay shaftt to slide in. we could it in about 2 inches worth and it would stop. we kept jiggling and fiddling and all of a sudden, bummff and it was in, ready for the wedge lock plate.
I put the top cover on to check the operation and it seems to work fine.
Now it's mating the OD to the gearbox and then on to oil filling and testing.
One more step towards completion! Yea!
Pictues attached
Tinkerman
Pictues attached
Tinkerman
