From the files of "it's never just one issue" -- got the mounts fixed, carbs back on and the thing still wasn't starting, but was on starting fluid. Spark was weak, so I changed plugs/rotor/cap/wires. Still not starting.
Opened up the fuel pump, nothing blocking, so I put it back together, and it kept leaking. Finally decided maybe the pump had always leaked a little.
Just tried an electric pump and it choked, grumbled, and finally started. After warming up, it started getting hot, so I shut her off. I lost some coolant when I changed the thermostat, so I'll have to make sure the system is full.
Also, my manual choke isn't hooked up...When I took off the carbs, it popped off, and I haven't figured out how to put it back on correctly (does anyone have a diagram or picture of a manual choke conversion as it sits at the carb?)
Have to properly wire the pump and get that choke working, then hopefully the thing didn't blow a headgasket at some point.
But at least it started!
