beez
I know the topic of tire sizes and speedometer error has been going back and forth for some time now but I have a few questions on the topic. I recently purchased some new 16” Panasports and would like to put on some high performance tires. I did some quick research on the tire sizes and the speedometer error that I will encounter with each size. Basically from the numbers I should go with 205/65R16 or 215/65R16 to get the closest numbers. The problem is there is a very limited (ie I didn’t find any) high performance tires in this size. I did find some high performance tires in the 225/60R16 size, but I believe they are too wide from what I’ve been told which is disappointing in that they are nearly the exact same size as the stock tires. If I drop down to 215/55R16 there are a number of choices and pretty much where I am leaning at this time. Again, the problem is these tires are about 5% to fast so if my speedometer said 60mph I would be traveling at 57 (theoretically… I know the tire pressure and other factors aren’t figured in). This isn’t too much of a problem as my truck is about 5mph faster than the speedometer read since the tires are larger that stock. All this said, I am curious to know how difficult it is to recalibrate the speedometer, if it’s possible to do at home, and do they make some kind of calibration box for this purpose (I want to use my stock speedometer). Also, are there some high performance tire options out there that I haven’t found?
Now if they had 17” Panasports…
Thanks,
Adam '73 TR6
Thanks,
Adam '73 TR6
