Yah I know. I dont want to risk removing the rear studs to replace them with new ones because I think doing so will just make the existing hairline cracks on the block bigger when doing the install.New nuts on OLD studs??????????????????
Mad dog
I've heard Grade 8 bolts could crack the block? What grade is the stock nut?They are 1/2 UNF, which is 20 threads/inch. You also should be CERTAIN to get grade 8 nuts and washers.
That said, I doubt that new nuts will help. If you can torque the old ones to spec, what's the difference between new and old?
That sounds like a plan.Sick idea, set the new studs with epoxy in the cracked areas. The force of tightening the stud
will push the epoxy into the cracks. Then you have new studs that can be torqued accurately.
If your block is the problem(?) this can hurt nothing. Metal bonding epoxy will handle the heat just fine.
Chase the threads where the issue is, coat the studs and set them in place.
Mad dog
Unless there is some new epoxy I'm unfamiliar with, many epoxy resins soften and is unusable at boiling point of water, 100C /212F. I wouldn't recommend using it on most anything engine compartment related, particularly the engne.That sounds like a plan.![]()
That's just not true. Look at ARP hardware, for example; it's actually much stronger than grade 8.I've heard Grade 8 bolts could crack the block? What grade is the stock nut?
